alternator underdrive pulley
with an electric water pump.i will be running just the crank and alternator off one belt.and the supercharger pulley with the other belt.is it even worth it to get an underdrive pulley for the alternator? thanks
RE: alternator underdrive pulley
wouldn't even waste the time I have an elec water pump witha idler on it to retain stock belt config (meziere pump) an elec fuel pump msd ignition, a stereo with amps, elec cooling fanetc ect........ so if you have alot of elec mods like me you'll need the charging amperage to run the stuff so all a underdrive pulley would do in your case and mine is lower charging out put. i'd just hurt ya' more than help. that's why I stuck with a stock one
Don't forget that he has the larger alternator that comes with the SN95 so it's not going to be the huge strain that you would normally see on a fox. But that being said, it's a waste of time anyway. Just spend the money elsewhere.
What supercharger are you running?
Golfsito
10-06-2015 11:02 AM
