Mass Air Flow Question
RE: Mass Air Flow Question
Sounds like you are on a tight budget if you are willing to attempt to drill your stock flow tube!
I'd suggest a C&L meter with the correct sampling tube, it's probably your cheapest route since you will re-use your stock electronics. Look on E-bay. prices are very good.
ORIGINAL: FivePointOhh
is this a good mass air sensor? http://www.jdsperformance.com/index....m&inmake=0
Well at the moment I have a pro-m 76mm MAF meter but its for my 19 lb'ers I fugure I could probably buy a new one and sell that ..lol probably make some money to.... Will the pro-m electronics work fine with a C&L housing and sample tube?
thats at least what the seller told me, if im wrong and it will not fit please let me know so i just put on stock 19lb ones. because my car was eating gas and i found out the reason why is because my injectors are sh*t....
Who is saying that you can run larger injectors without a chip / tune / calibrated MAF? Do you have a link to this? 22.5 lb injectors for your 5.0? I've gotta say that this would be a first for me. I've never seen any rated at 22 1/2.
Even if they did exist, according to your sig you're bone stock. Why would you get larger injectors?
