Mass Air Flow Question
#21
RE: Mass Air Flow Question
i think they do infact make them... some SD guys use them to get a little more fuel going on... its not much, but its slight enough that the system isnt fubar, just rich.... either way i wouldnt do it
#22
it will waste more fuel but it will have an effect on the speed...
so you guys think that 22.5 pounders are not worth it and i should just replace mine with 19 pounders...
also do you guys think the remanufactored ones on ebay are good or not worth it and i should go with new ones...
new ones literally cost 3 times more...
#24
ORIGINAL: dimebag
uh, why replace the ones you have?
i think ill save money on the long run, plus my car will drive better...
if anyone has millege problem they should look into these things...
#26
yeah i know people do that...
would i be able to do it myself?
it looks like its hard to reach...
you as a mechanic what do you think would i be able to do it...
i can see them but hard to reach i have a 95 gt btw...
#27
So your mechanic is telling you that if you replace 19# injectors with larger injectors, you will get better mileage? If you don't get a proper tune when you get the larger injectors, then your fuel consumption is going to increase and your mileage will get worse. Either your mechanic is an idiot, or he's just an ******* trying to rip you off. The computer can only compensate for so much.
#29
wow....that is....hilarious almost.
i need to get a job in a mechanic shop, i hear these stories all the time
sorry about the mis info droptopred.....i think your mechanic is trying to be funny or is an idiot
Luke9222
10-22-2015 11:55 PM
