HCI 99% Complete - Help with last line! *NEED HELP!*UPDATED**
RE: HCI 99% Complete - Help with last line! *PLZ HELP!*
Got underneath the car with a ratchet and a 15/16" socket . Also, you may be able to spin your motor by turning the alternator pulley if your belt is on there tight, I'm able to do that.
Thanks Vig! I'm going to attempt this... I spent eight hours putting the car back together last night... not including the other 8 the night before.... I'm probably pushing 30 hours total on the car now...
to check and see if you stuck the dizzy wrong you can just swap the wires around. put #1 directly across from where it should be and do the same with the rest of the wires. its a 5 minute quick check to verify the problem
ORIGINAL: my77stang
Also... Should the car start right up after HCI??? I didn't pour oil in the lifter valley is this going to make a difference?
ORIGINAL: nothsa
I wish I would've known that 5 minutes ago before I broke my #1 spark plug in half... Anyways i'm going to try that when I get the new plug...
ORIGINAL: my77stang
ORIGINAL: VigCS
My car started after a few seconds of cranking when I got the dizzy in there correctly. I don't think pouring oil in would be hugely critical, but your lifters may be noisy until some oil gets flowing through them.
ORIGINAL: nothsa
ORIGINAL: my77stang
Any other recommendations on starting the car? Let it sit on the on position? etc?
Not to confuse you anymore, but all you have to do is get someone to help you. Once you get the #1 plug out, have him rotate the crank using a deep socket and a ratchet until you feel air being forced through the seal that you created with your finger over the spark plug hole. This will tell you that you are on the compression stroke.
What I do is stick a screw driver through the spark plug hole until it rests on top of the piston, then have a buddy keep turning the crank until the screwdriver is pressed all the way to the top. This tells you that the #1 piston is at TDC on the compression stroke. NOW is when you stab the dizzy and double check your firing order.
OMG!!! It started WOOHOO!!!
I can't get it to start anymore... but it did start!
That last line is still disconnected and Vig said it goes to the lower intake. Does it connect to the hole in the lower intake? Does it fit in there? It won't reach there if it is supposed to go there so I will need to get another pcv line i'm assuming.
Please help with this last part guys! The beast has almost awaken lol!!!
-Jeff
-Jeff
