tuning fuel pressure regulator
you can tune the fuel pressure regulator right?
i don't have an a/f gauge so how do i know what its good to leave the regulator at cuase atm i got a pretty often backfire and mostly low rpms.
RE: tuning fuel pressure regulator
41psi. even with a wideband o2 you cant really tune a car with fuel pressure. you can if your just slightly off but any major change must be done by changing injector pulse width
+1. Tuning using fuel pressure and timing is a cheap / crappy way to tune a car. If you find that you're running a little lean or rich then adjust the MAF transfer which will in turn, alter the injector PW.
zanemoseley
09-06-2015 12:58 PM
