Heater tubes can they be removed?
Old 07-12-2007, 02:39 AM
Ze2222
Ze2222's Avatar
Default Heater tubes can they be removed?
As the title states, i was wondering if u can remove those pipes that went to the heater core?what would u do with ur coolant temp sensor can it be plug into somewhere else? any help would be appreicated thx.
Ze2222 is offline
Old 07-12-2007, 04:27 AM
greenstreak9205
greenstreak9205's Avatar
Default RE: Heater tubes can they be removed?
are you asking if you can remove the heater hoses and the heater core from the coolant system all together? if so then yea they can be removed but you'll obviously not have much heat on the "heat/hot" setting. just make sure that you still have some coolant going to the egr spacer. despite what some believe, ford put it there for a reason and it actually cools the intake temp charge using the coolant. just jump the hoses and thats all.... hope this helps you a bit
greenstreak9205 is offline
Old 07-12-2007, 09:31 AM
nseoi
nseoi's Avatar
the two hoses going to the heatercore can be joined together so that the heatercore is eliminated. JOIN THE HOSES. when i bought my car they had capped the 2 lines and everytime i would floor the gas one of the caps would burst and spray coolant all over. its a circuit, so if you take off the heatercore keep it as a circuit
nseoi is offline
Old 07-12-2007, 09:35 AM
5.0stanger
5.0stanger's Avatar
You can remove the hard lines and put the ECT in the hole in the intake where you removed the piping from.
5.0stanger is offline
Old 07-13-2007, 02:00 AM
Ze2222
Ze2222's Avatar
ahh k yes ur right!!! I have another question now just curious how important is it to have the coolant running through ur throttle body?? I found a way to eliminate the hardlines and still keep the coolant running through the throttle body but it would be nice to be able to eliminate the coolant line going to the throttle body clean up the engine bay even more
Ze2222 is offline
Old 07-13-2007, 02:31 AM
greenstreak9205
its ur car and you do what you want, but i would keep it....
Old 07-13-2007, 07:53 AM
5.0stanger
5.0stanger's Avatar
I removed mine.....but I also removed the EGR.
Old 07-13-2007, 07:59 AM
P Zero
P Zero's Avatar
Just get a carb
-P.
P Zero is offline
jwog666
12-27-2021 08:09 PM
mrtrodonet
09-19-2020 03:12 PM
daltron
04-28-2016 08:10 PM
Dathan
10-05-2015 05:52 AM
jrrhd73must
10-02-2015 09:17 PM
Quick Reply: Heater tubes can they be removed?
