351w Flywheel Question
Ok Ive been having starter problems and Ive finally decided to pull out my flywheel. I got it out and measured it with a Dial Indicator and it was off .020 now is this enough to damage my starters? Also I was just gonna replace it anyways because I was told it was pretty bad. From what Ive been reading im gonna need a 157T flywheel 28 oz ? its for a 351w with T5 tranny. Any help will be greatly appreciated
RE: 351w Flywheel Question
It could probably be from anything as long as it's 157T 28 oz. But honestly, you should spend the extra cash and get a good quality billet steel or aluminum flywheel to replace it, as the stockers don't fair too well with too many mods. I got my billet steel flywheel (same one you need) from Astro Performance. I think it was like $170 to my door. Thats CHEAP. Just remember if you buy from them, check the flywheel bolt holes before installing it. It takes a 5/16 x 18 bolt, but my holes had to be retapped to fit a 5/16 x 18. It would only thread in about 2 turns until I retapped it which took all of5 minutes. So you need to question them about that first. Otherwise, it's been good so far.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
junior04
09-28-2015 10:53 AM
