still got issues
Old 07-13-2007, 03:09 PM
chosen1_50
chosen1_50's Avatar
Default still got issues
I have changed the fuel filter, new gas with seafoam treatment clean the trottle body, gas is getting to the injector so the fuel pump seem to be working,but the car will stay started any other suggestions.
chosen1_50 is offline
Old 07-13-2007, 03:10 PM
red95gtconvert
red95gtconvert's Avatar
Default RE: still got issues
Don't you want the car to stay started?
red95gtconvert is offline
Old 07-13-2007, 03:13 PM
chosen1_50
chosen1_50's Avatar
I mean it will not stay started or idle.
Old 07-13-2007, 03:32 PM
tmajikman
tmajikman's Avatar
Did you pull the codes by running the koeo and koer tests if you can get it to run. That may tell you where the problem is at.
tmajikman is offline
Old 07-13-2007, 04:04 PM
94Blk5.0
94Blk5.0's Avatar
Check for codes, as mentioned, but in the mean time look for after obvisous vacuum leaks, lose hoses etc. Probably not an issue but check the MAF senor as well, needs to be clean.
94Blk5.0 is offline
Old 07-13-2007, 04:29 PM
mattdel
mattdel's Avatar
IAC
mattdel is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
12-08-2015 04:37 PM
Thunderball
15
11-22-2015 11:49 PM
chrisdbassplayer
10-13-2015 06:53 PM
Bokeo
10-10-2015 08:28 PM
Quick Reply: still got issues
