cleaning injectors
RE: cleaning injectors
Are you removing them to clean them , because you think that will cure your no start???? or does the car run now???? if not you still need to do that fuel pressure test or all your work may be for not???
no im not cleaning them cuz i will think it will solve anything.. i want to clean the tb and egr cuz when i look in them they are blacker then black inside lol
and the injectors because they may be clogged and it would be good to clean them n e ways..
but i do think it is a fuel pump issue but i do really need that testor... does anyone know where i can buy one thats not online? thanx
ok so i took it all apart, cleaned them using the method i stated b 4 and they seemed pretty clean, a uniform stream came out of all of them the first try.. so i installed new orings and put it all back together.. took about 3 hours
thanx guys
thanx guys
