VALVE NOISE? OH NO
RE: VALVE NOISE? OH NO
no i didnt measure the length , my 77 stang i cant see anything in your post bro, I have another idea would the stock pushrods say from a cobra be close enough ? i know they came with the same rockers i have in my setup.
ORIGINAL: 5.0stanger
If they are loose, you need longer push rods, if they are too tight, you use the shims that came with them. To adjust rockers, first, loosen all you rockers. Then start on the number one cylinder, rotate the engine till you see the rocker/push rod you are adjustingmove up and down, keep going till the push rod right next to it(same cylinder) just starts moving up, now you know you are on base circle. Take the lash out(free play) until you have no up and down movement in you push rod but it will still spin freely by hand. From that point, (you have pedestals I assume) you torque to spec of 19ft/lbs. While torquing to that spec after lash you should have no more than one full turn and no less than 1/4 turn. If you have more than one full turn you will have to add a shim, if you have less you will need to remove a shim or get longer push rods.
ORIGINAL: 94 G STANG
ya sorry the rockers are making noise, how do you adjust them?
i thought they cant be adjusted
ORIGINAL: samseed101
This is completel yoff topic, but I just noticed your sig. Best movie ever But how many people out there recognize it?
ORIGINAL: jebarr
OFFICE SPACE!!!!! It is one of the greatest movies that nobody knows.
