Hole in my water pump!??!!?!
Old 07-15-2007, 08:25 PM
goathead75
goathead75's Avatar
Default Hole in my water pump!??!!?!
Can anyone tell me what this hole is and if it's supposed to be there? It looks like something might have been threaded in there, but definitely doesn't look normal. I started looking around since I started hearing what sounds like a little bearing noise out of the front of the motor and I noticed the fan was wobbling a real slight bit and then saw this hole. If you look into it, I think you can see the shaft going to the impellar. Not normal, is it?
[IMG]local://upfiles/49188/8E0269EB022E4AC8ACD88D3B1F10162A.jpg[/IMG]
[IMG]local://upfiles/49188/C4497B4ED9284DAE8DB3DAE690E85121.jpg[/IMG]
goathead75 is offline
Old 07-15-2007, 08:27 PM
getafewlives
getafewlives's Avatar
Default RE: Hole in my water pump!??!!?!
Its supposed to be there. As long as no coolant leaks than your fine. If its leaking, which is a common problem for the water pump, then it is shot and you will need a new one.
getafewlives is offline
Old 07-15-2007, 08:28 PM
getafewlives
I believe its the weep hole or something. Thats where coolant started leaking on my old mustang. Sinple replacement fixed the problem.
Old 07-15-2007, 08:44 PM
my77stang
my77stang's Avatar
yup thats basically the "your water pump is f*cked" indicator
my77stang is offline
Old 07-15-2007, 08:48 PM
goathead75
goathead75's Avatar
So can the water pump make that kind of bearing noise before it goes? With that noise and the fan wobbling, that's what i'm thinking it is. Any other way to verify it without changing it?
Old 07-15-2007, 08:54 PM
adumb
adumb's Avatar
my fan was wobbling and i though it might have been the water pump but after replace the water pump(it started leaking anyways) then the plastic part of the fan i only had one option left which was the fan clutch. the fan clutch is what ended up fixing the wobbling fan for me. i belivee it is like 30 bucks at autozone.
adumb is offline
Old 07-15-2007, 08:56 PM
luckythirteen13
luckythirteen13's Avatar
ORIGINAL: goathead75
any moving part can make that noise
luckythirteen13 is offline
Old 07-15-2007, 09:18 PM
my77stang
my77stang's Avatar
i'd say 98.73619% chance that wobbling = fan clutch bad. perfect excuse for a junkyard electric fan conversion[8D][8D][8D]
Old 07-15-2007, 09:22 PM
luckythirteen13
ORIGINAL: my77stang
[sm=exactly.gif]
Old 07-15-2007, 09:43 PM
86 5.0L
86 5.0L's Avatar
ORIGINAL: luckythirteen13
ORIGINAL: my77stang
[sm=exactly.gif]
+1
86 5.0L is offline
Quick Reply: Hole in my water pump!??!!?!
