what will a 5.0 do with larger injectors only?
RE: what will a 5.0 do with larger injectors only?
so can the stock fuel pump keep up with 24# injectors if there a demand to use more fuel? what do i do to make use of a set of bigger injectors?
ORIGINAL: nothsa
Nope... The 24lb injectors are there to supply more fuel which isn't needed ona stock motor.
ORIGINAL: 86GT 93LX
ORIGINAL: nothsa
I am using 24lb injectors with my stock fuel pump... I'm actually getting my MAF recalibrated tomorrow for the bigger injectors. Make sure when you get bigger injectors you have your MAF recalibrated in accordance.
-Jeff
im not sure how flexible the ecu is on a 86 but someone said changing to a 3bar map sensor will do something, i cant remember and i dont know what a 3bar map sensor is anyways!
ORIGINAL: nothsa
That explains the 86 being your 5.0! SD FTW!
ORIGINAL: 86GT 93LX
i dont have a MAF my car is speed density
