Stuck bolts
Old 07-18-2007, 11:49 AM
red9535
red9535's Avatar
Default RE: Stuck bolts
ORIGINAL: bds95stang
ORIGINAL: Fox87
Thanks for your suggestions! It seems I heard somewhere that heating and cooling the bolt might help, any truth to this?
you dont heat thebolt you heat around the bolt
Correct. The concept is that when metal is heated up, it expands. So you take a torch to the area around the bolt. The bolt hole heats up and expands, leaving you with extra room to try to yank the bolt out. Good luck, do it fast! They cool down quick!
red9535 is offline
Old 07-18-2007, 01:39 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
The tools name is an easy out and as stated above: "drill it put the tool in and back out the bolt and the stuck bolt issue is gone" HA HA HA LOL LOL You smoke crack or what??? if it were that easy it wouldn't of broken off. gauranteed the best way will be to remove the timing cover leaving as much of the shank exposed so you won't have to drill easy out and re tap hole... then lightly heat around the base of the bolt and using a stud removal tool or good ole fashioned vise grips back out bolt. if all else fails cut off flush and drill it out re tap or install a helicoil
mjr46 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
baddog671
07-26-2016 01:20 PM
2poor4u2
09-26-2015 11:08 AM
maestro1024
09-21-2015 02:40 PM
Quick Reply: Stuck bolts
