Stuck bolts
Old 07-17-2007, 04:06 PM
Fox87
Fox87's Avatar
Default Stuck bolts
Well I am replacing my water pump as we speak and I have now broken one bolt and have another that is so stuck I know I will break it if I really crank down on it. I know you all, as car guys, have your own ways of removing stuck bolts, and I was hoping you guys could share some of those with me.
Fox87 is offline
Old 07-17-2007, 04:17 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
Default RE: Stuck bolts
there is a tool that looks like a drill bit. you make a hole a little smaller than the bolt witha drill bit, then you use this tool and screw it in. it gets wedged in there real tight and then you crank it back out and your bolt issue is gone.
or you can drill out your hole, and tap it again but then you need a bigger bolt. i advise next time anti seize
FivePointOhh is offline
Old 07-17-2007, 04:25 PM
TwotoneVert
TwotoneVert's Avatar
I replied to your thread in General Tech.
TwotoneVert is offline
Old 07-17-2007, 05:15 PM
94 G STANG
94 G STANG's Avatar
you have to pull of the timing cover if all else fails and snap on sells a tool that grabs the bolt and tightens as your try to loosen the bolt.
I had to do it that way good luck.
94 G STANG is offline
Old 07-17-2007, 05:16 PM
Fox87
Fox87's Avatar
Thanks for your suggestions! It seems I heard somewhere that heating and cooling the bolt might help, any truth to this?
Fox87 is offline
Old 07-17-2007, 05:17 PM
blkonblk5.0
blkonblk5.0's Avatar
yes it helps alot
blkonblk5.0 is offline
Old 07-17-2007, 05:18 PM
Fox87
Fox87's Avatar
ok, ill start in on doing that then. at this point, if it doesnt work, ill probably just break this one too and drill/tap. Might go faster in the long run.
Fox87 is offline
Old 07-18-2007, 08:00 AM
Jfsram
Jfsram's Avatar
If it's the shank frozen to the aluminum water pump or housing you can try this.
Go ahead and break the head off. Remove the remaining bolts. Now twist and pry the housing off the headless bolt. It's probably the shank of the long bolt caked with corrosion from the water pump.
Jfsram is offline
Old 07-18-2007, 11:19 AM
Fox87
Fox87's Avatar
I did remove the water pump with that method, unfortunately, the bolts are still stuck in the engine block, I have about four inches of the bolt still to work with so hopefully with the heating/cooling method I will be able to get it out without drilling and tapping.
Fox87 is offline
Old 07-18-2007, 11:33 AM
bds95stang
bds95stang's Avatar
ORIGINAL: Fox87
you dont heat thebolt you heat around the bolt
bds95stang is offline
Quick Reply: Stuck bolts
