T-5 tranny
RE: T-5 tranny
ORIGINAL: shawnk007
Why would they be different trannys if they bolt to the same blocks? Would it work if I used the flywheel from the 95?
the bellhousing was made deeper and the input shaft made longer because the passenger compartment was moved further back in the SN-95 body style... the engine is literally 1" further away in an SN-95 than it is in a fox.
RE: T-5 tranny
ORIGINAL: shawnk007
what do you mean by the ball? the flywheel? cuz I can get the flywheel, clutch and tranny in this deal. wud it still not work?
god, I mix up one vowel and i screw up the entire world!
RE: T-5 tranny
ORIGINAL: shawnk007
So, if I used the bellhousing from the 95, it wud work? Would I need a shorter driveshaft?
why dont you just suck it up, and swap the damn input shaft.... its a friggin 30 minute job
