pplease help me out here
Old 07-18-2007, 04:53 PM
pete97GT
pete97GT's Avatar
Default pplease help me out here
I was driving home on a hot day, got stuck in traffic and my car was starting to run really hot due to a very crappy haynes fan ( just got a taurus fan but have not put it on), the temp got too hot so i turned on the heater to lowerthe tempa little. then all of a sudden my oil pressure dropped to zero, pulled over checked for leaks and found nothing. The oil pressure only dropped at idle, so when i reved it up it went back up to about half way. After I let the car cool the oil pressure stopped dropping. It seemed that the pressure dropped only when i had the heater working... sounds kind of wierd, but can they be related at all? anyway there are a number of things that i think could have gone bad, so i need your advice on this. First of all my motor has about 80,000 miles on it (or so the guys said) out of a 92 gt. I have a pulley or harmonic balancer problem and the crank shaft pulley wobbles ( which i am fixing today) COULD THIS HAVE SCREWED UP MY CRANK/BEARINGS? if so, would thepressure just drop for good? Also the guy who i bought the car from was using 5w-30 fully synthetic oil, which i am obviously still using, however is it possible that the oil is too thin?? Lastly my car idles at about 1000rmp, is that bad idle , if so how can i adjust it????? I appreciate any info on this, thanks
pete97GT is offline
Old 07-18-2007, 06:49 PM
pete97GT
pete97GT's Avatar
Default RE: pplease help me out here
also how would I know if the bearings are bad just by looking at them??/
pete97GT is offline
Old 07-18-2007, 07:42 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
way to many questions!!! first after the gauge hit 3/4 you should of shut it off pulled over ect ect....... if you got it sky rocket hot then of course the oil would of thinned out to like water!!! let it cool then see if you have a oil pressure problem and change the oil you probably cooked it I could go into a lengthy disscucion about what happens to the properties of oil under extreme temps but lets leave it at that. if you cooked your motor next time pull over before that happens[&:] and fix the harmonic balancer! with it wobbling it doesn"T help the bearings out as it throws the balance off and creates unwanted harmonics, if you don't hear a rod knock or main bearing rattle don't worry about it cause if you damage them due to neglect then what's done is done so when you change the oil look for metallic particals in the oil that'll confirm any suspicions. AND FOR CRAP sake don't drive a car past the 3/4 mark ever if it's allways run in one spot then out of the blue it runs hotter shut it off immediately do no pass go and do not collect yo' 200 huhand dolla'.....It ain't worth toastin' a motor
mjr46 is offline
Old 07-18-2007, 09:21 PM
pete97GT
pete97GT's Avatar
thats what I did, I pulled over, let it cool off. and then got stuck it traffic again, it was barely over 3/4 mark, damn really dont want to put new oil in, just spent 30bucks on an oil change.
pete97GT is offline
Old 07-18-2007, 09:48 PM
mjr46
mjr46's Avatar
If you don't check condition of oil you'll never know if there is metal in it. but wait until the morning and start it again and see if oil pressure is okay....bring it up to operating temp and see if pressure is okay. if it is then you dodged the bullet hopefully for now.
mjr46 is offline
Old 07-18-2007, 10:50 PM
creekrat
creekrat's Avatar
Dude, if you cooked your oil, replace it! 30 bucks is a lot cheaper tha a rebuild!
creekrat is offline
Old 07-19-2007, 12:59 AM
SoDakStang
SoDakStang's Avatar
^^I agree!
Does you car have coolant in it. Just a thought, but check that if you haven't already. Check the easy stuff before assuming you roasted your engine. Change the oil and eat the 30 dollar bullet. It's just 30<2000
SoDakStang is offline
Old 07-19-2007, 03:53 AM
pete97GT
pete97GT's Avatar
oh i know i didnt toast the engine, the car ran fine after i let it cool off a bit, the oil pressure went back up and then after i let it cool off i drove it home fine, and yes i def have coolent in there
pete97GT is offline
Old 07-19-2007, 08:07 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
are you looking at your stock oil pressure gauge?
FivePointOhh is offline
Old 07-19-2007, 02:01 PM
pete97GT
pete97GT's Avatar
yes
pete97GT is offline
Quick Reply: pplease help me out here
