Drive Shaft Compatibility?
Old 07-19-2007, 01:24 PM
Alero99
Alero99's Avatar
Default Drive Shaft Compatibility?
Well i am gathering all my components for an AOD to T-5 Swap and i wanna know if the aluminum drive shaft on AmericanMuscle.com is compatable with both my current AOD and the T-5 i want to put on...
my AOD is rebuilt and in my 88GT t-5 is from an 87GT and will more then likely get rebuilt
just want to know if i can like throw it on my current set up and when i do the swap use it again?
http://www.americanmuscle.com/frp-79...riveshaft.html
Alero99 is offline
Old 07-19-2007, 01:28 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
Default RE: Drive Shaft Compatibility?
it says right on the article it is
Ford Racing's Light Weight Aluminum Drive Shaft for 1979 through 1995 5.0L Mustang's is designed to reduce stress on your car by reducing the rotating mass of your drive train. Less weight means better power transfer allowing you to put more horse power to the ground.
Constructed of light-weight, high-strength seamless 3.5" diameter aluminum tubing. Ford Racing's Light Weight Aluminum Drive Shaft is built to last and is the perfect replacement for your street or strip car.
Specifications:
[ul][*]Application:
[ul][*]1979-95 Mustang/Capri 5.0L vehicles with T-5/SROD/C-4/A0D Transmission [*]1979-93 with Tremec Transmissions[/ul][*]Axle Compatibility: 7.5" or 8.8" Differentials[*]Spline: 28[*]Material: Aluminum[/ul]
FivePointOhh is offline
Old 07-19-2007, 01:32 PM
Alero99
Alero99's Avatar
yea but i really don't trust what they write... cuase somtimes you ahve to make little adjustments, lets say i have to adjust to ge tit on my AOD but when i do my t-5 the adjustment was perminent now i have to get a new one.... comprende?
Alero99 is offline
Old 07-19-2007, 01:54 PM
FivePointOhh
in limbo
ORIGINAL: Alero99
]├╡╞\3╛h♥½▄OΣµ[∩¬÷Äα╗φ
^^ thats all i saw and i say what?
it will work
Old 07-19-2007, 02:08 PM
ZachW04Stang
ZachW04Stang's Avatar
Its works on all the transmissions listed.
ZachW04Stang is offline
Old 07-19-2007, 03:01 PM
Alero99
Alero99's Avatar
excellent shall have it before teh summe ris over maybe
Alero99 is offline
Old 07-20-2007, 11:30 AM
Alero99
Alero99's Avatar
what does this install typically run people?
Alero99 is offline
Old 07-20-2007, 05:28 PM
89GTdude
89GTdude's Avatar
Do you really want to pay to have someone install it? Its only a matter of 4 12mm bolts and maybe a extension housing seal if its bad?
89GTdude is offline
Old 07-20-2007, 08:53 PM
ALMOST STOCK
ALMOST STOCK's Avatar
If he doesn't trust what he reads ( and the facts are right there) , then yeah he needs someone to install it for him.
ALMOST STOCK is offline
Old 07-21-2007, 02:07 AM
Alero99
Alero99's Avatar
here is why i don't trust it... cuase many companies like bbk make products that are compatible with your car, doen't mean it doesn't need some altering to fit.... example bbk equal length headers,, rub the ****ing stgeering shaft and arr known to melt the spark plug wires get it? i am not a mechanic so if this is anything more then just a unbolt and rebolt job then i probably won't be able to do it
Alero99 is offline
Nick Oliver
10-17-2018 04:22 AM
StalkerGT
09-25-2015 02:41 PM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
09-08-2015 11:50 AM
Quick Reply: Drive Shaft Compatibility?
