whats causing this??
Old 07-19-2007, 02:35 PM
pete97GT
pete97GT's Avatar
Default whats causing this??
just put a new 130a alt on and as I start it for the first time with the newalt my starter grinds againsnt the flywheel, its like its not disengaging, replaced the solenoid, same thing, replaced the relay, same thing, bench tested the starter, it passes, tookit apart and there is no physical damage that i can see, i tried disconecting the alt and starting it without it and the starter does the same thing, grinds against the flywheel for about 1-2 secongs and only after disengages, WHAT IS CAUSING THIS!!?? it used to never do this. so confused, help me out here,
pete97GT is offline
Old 07-19-2007, 02:48 PM
mattdel
mattdel's Avatar
Default RE: whats causing this??
bench testing a starter isn't always accurate...
it's sticking. replace the starter.
mattdel is offline
Old 07-19-2007, 02:50 PM
Tims 88GT
Tims 88GT's Avatar
^^agreed
Tims 88GT is offline
Old 07-19-2007, 02:53 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
there should be a small wire usually it's a 90 degree elbow shaped wire that attaches to one leg on the starter selonoid that's mounted on your fender this is the wire that is hot/ has current on it in the crank position. this wire is the wire that has current on it to energize the windings inside the selonoid that bridges the hot always side of the selonoid to the starter side of the selonoid.......anyway put a test light on this wire and immediately after you release the ignition switch from the cranck posiotion to the rest/run position the light should go out... if not the problem rests in the ignition switch and no I don't mean where you stick the key usually down on top of the column there is a electrical portion for the ignition switch.. all the key and tumbler do is rotate as to push a rod to engage different contacts in side the switch. my bet is it's a sticking switch.
mjr46 is offline
Old 07-27-2007, 04:23 PM
pete97GT
pete97GT's Avatar
replaced the switch, didnt fix the problem though, does anyone know what the black/white wire that goes to the right side of the starter relay ( one that mounts on the fender) does? Or rather the big resistor type looking thing, its 1/2" by 1" thing thats got two terminals.
pete97GT is offline
Old 07-28-2007, 03:55 AM
pete97GT
pete97GT's Avatar
oh nvm, just a circuit breaker and replacing that didnt fix it either,
pete97GT is offline
Old 07-28-2007, 06:38 AM
creekrat
creekrat's Avatar
Did you replace the starter???
creekrat is offline
Old 07-28-2007, 08:13 AM
adumb
adumb's Avatar
nice subject title... very specific
adumb is offline
Old 07-31-2007, 02:57 AM
pete97GT
pete97GT's Avatar
no, will do though
pete97GT is offline
cr620
10-03-2022 10:18 PM
Thunderball
15
11-22-2015 11:49 PM
Dathan
10-05-2015 05:52 AM
GLOCKer
09-28-2015 07:36 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: whats causing this??
