i need alot of help guys..
RE: i need alot of help guys..
Why don't you just take the cable loose from the fork and check the action of the pedal assembly without the tranny hooked to it. This will tell you where you should be looking for the problem. If the pedal it still tight with it disconnected, there is no need to drop the tranny
ORIGINAL: creekrat
ORIGINAL: creekrat
mjr46 do you have a firewall adjuster or a aftermarket quadrant on your pedal assembly. i wish you were closer i would love to route around and see if i could find the problem.
my stock cable i have wasn;t the same size as my buds on his stang.. when i putmine on the car there was too muchslackat the pedals it would fall off oncethe pedalcame outnow imgoin to try a fewthings withit tommmrow because themy adjustable cable snapped from the tigtness and tension being so great on it.. it snapped where it comes through the bell housing where its held in place
ccdguy
09-19-2015 05:20 PM
