To Tilt Or Not To Tilt. That is the question....
OK. I searched and I didn't see any positive answers for this question. I have a 90GT (no tilt steering) is it possible to swap this out with one of the old foxes that did have the tilt wheel? If so what all has to be done? Thanks!
RE: To Tilt Or Not To Tilt. That is the question....
swapping the column should be as easy as any other bolt in project.
you will, however, have a flashing air bag light, unless you remove the airbag diagnostic module in the dash.
little blue box, a bit smaller than a radio, located behind/above the heater controls
ORIGINAL: mattdel
ORIGINAL: mattdel
lol, where they ya go. grab your socket set and go.
there is a possibility of running into a wiring problem, with mismatched harnesses.
if that should become the case, post another thread. more than a few of us have access to AllData and whatnot, and we can give you the info you need.
ORIGINAL: mattdel
ORIGINAL: mattdel
