rear end
Old 07-19-2007, 03:55 PM
1990mustanglx
1990mustanglx's Avatar
Default rear end
i have an 89 rear end still on the car with 410s and i have an 83 with stock gears and i think a 7.5 inch rear can i jsut take the rear end out and put it into the 83 easily? are rear end easy to take out?
1990mustanglx is offline
Old 07-19-2007, 03:58 PM
turbosha
turbosha's Avatar
Default RE: rear end
sure , will bolt right in. there not to bad to swap if you have a buddy. there heavy and bulky to move around by your self.take the driveshaft,emergency brake cable,brake line,and the 4 control arm bolts. and itll fall out
turbosha is offline
Old 07-19-2007, 04:04 PM
1990mustanglx
thank you
Old 07-19-2007, 04:06 PM
stang8689
stang8689's Avatar
check your bushings in the 89 rear, might need new ones, probably need some heat to replace them
stang8689 is offline
mtgldr
02-03-2024 09:00 PM
zsmart
Convertible Tech
02-29-2016 08:33 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
fastbackford351
09-12-2015 09:42 AM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: rear end
