GOT HER RUNNIN TODAY
Old 07-19-2007, 07:31 PM
Jon_Boy
Jon_Boy's Avatar
Default GOT HER RUNNIN TODAY
So i finally got my mustang back together today. WHO ever had this car before me is a dumbass. He stripped some bolts out in the intake manifold. ANY WAAAYS. SO i get it all buttoned up and im ready to start it. Get in it, and turn the key and it starts right up, and sounds GOOOOD!!! i get out of the car and its POURING WHITE SMOKE out of the exhaust. It smells like firecrackers almost!! Im like WHAT THE HELL....and i notice that the back of the lower intake is pouring freaking oil out.
SOOO what do you guys think is the problem???? Im open to suggestions!!
Probally going to buy another motor tomorrow.
Do yall think $300.00 is reasonable for a Bored .30 Over 302??
Jon_Boy is offline
Old 07-19-2007, 07:38 PM
gsxrstang69
gsxrstang69's Avatar
Default RE: GOT HER RUNNIN TODAY
Did you use the gaskets that came with the gasket kit for the front and back or did you use silicone?
gsxrstang69 is offline
Old 07-19-2007, 07:48 PM
Jon_Boy
Jon_Boy's Avatar
I used silicone. I know i didnt use enough, and thats why it's leaking.
That wouldnt cause it to smoke for the tail pipe
Jon_Boy is offline
Old 07-19-2007, 07:52 PM
gsxrstang69
Actually it might be the cause. You might not have sealed it comepletely and now you have a vacuum leak. This is leaning out your Air/Fuel ratio since un-metered air is getting into your motor. Also check your timing.
Old 07-19-2007, 08:39 PM
creekrat
creekrat's Avatar
Is the smoke actually coming out of the exhaust pipes or just out from under the car? With that big of an oil leak that close to hot exhaust and the cooling fan blowing, could just be the oil burning off the pipes!
creekrat is offline
Old 07-19-2007, 08:57 PM
Jon_Boy
Jon_Boy's Avatar
Its actually coming out the tail pipes. I have big chrome tips!!!
Jon_Boy is offline
Old 07-19-2007, 08:58 PM
my77stang
my77stang's Avatar
sweet!!!
my77stang is offline
Old 07-19-2007, 09:02 PM
gsxrstang69
Just rip off the lower and reseal it and your problems will be solved....and make sure your pcv valve is in
Old 07-19-2007, 09:24 PM
NYMustang50
NYMustang50's Avatar
$300 built like pistons everything crank rods cam heads or what?
NYMustang50 is offline
Old 07-19-2007, 09:26 PM
Jon_Boy
Jon_Boy's Avatar
Complete Motor, bored .30 over. Stock rods and crank, "E" cam.
300
Jon_Boy is offline
chrisdbassplayer
10-13-2015 06:53 PM
KingRando
10-02-2015 08:06 AM
Explosive
10-02-2015 07:45 AM
mungodrums
09-28-2015 10:54 PM
09-23-2015 01:28 PM
Quick Reply: GOT HER RUNNIN TODAY
