Found a real 93 Cobra intake
RE: Found a real 93 Cobra intake
ORIGINAL: stang8689
Your in for a disappointment. First off they say 20 horse gain but it depends on mods. If everything is stock probably 7 horse or even less. If you have heads, cam, exhaust,throttle body and other bolt ons with a stock intake you would proably get 20 horses going to the Cobra. Its still a niece piece, I used to have one. If you can get for $200 or less thats cool.
Get the intake if you can, always a good step in the right direction. You should also look inot a set of 1.7 RR to make you cam more into the cobra spec to help with the intake.
I felt a good boost in performance when I swapped my TF street heat manifoldonto my stock motor. It's worth a noticable SOTP gain. I'd save the money up for a full exhaust though. Been there and done that, you'll like the exhaust much better.
How about not commenting unless you've actually done the swap. You will gain around 15 to 20 horsepower. I had a stock motor with ford f cam and went to the "chineese crap" cobra intake and went from 9.60's consistently to a 9.1. Agreed you wont see that from a stock motor, but it will definately be worth the swap.
09-01-2015 08:16 PM
