hurst shifter
Old 07-20-2007, 12:25 AM
lecznar1
lecznar1's Avatar
Default hurst shifter
hey guys i have a hurst on my 94 gt and it keeps coming loose!! it's really annoying... does anybody else have a hurst with this same problem?? i think i might just get the steeda tri-ax
lecznar1 is offline
Old 07-20-2007, 12:26 AM
primetime5.0
primetime5.0's Avatar
Default RE: hurst shifter
coming loose? can you give a little more detail?
primetime5.0 is offline
Old 07-20-2007, 12:29 AM
lecznar1
lecznar1's Avatar
you know those two bolts that hold the shaft and head together that go through the middle of the shifter, they are always coming loose and i have no idea why.... no matter how hard i tighten them they always come loose
lecznar1 is offline
Old 07-20-2007, 12:31 AM
primetime5.0
is it threaded on one side? could you put a nut and bolt on it so it wont come loose?
Old 07-20-2007, 12:42 AM
lecznar1
lecznar1's Avatar
that's the thing there isn't a nut on it and it's only long enough to just bareley go through the other side of the shifter
lecznar1 is offline
Old 07-20-2007, 01:28 AM
iceman89gt
iceman89gt's Avatar
loc tite in the red bottle..... put a little on it and be done with it
iceman89gt is offline
Old 07-20-2007, 06:54 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if your using the stock shifter handle with a hurst base toss it!! the rubber on the stick skews how tight it'll get or like mentioned above loctite it.
mjr46 is offline
Old 07-20-2007, 07:21 AM
hellion_79
hellion_79's Avatar
iceman is right, try some lock tight and see if that works. and automotive store should carry it
hellion_79 is offline
Old 07-20-2007, 10:59 AM
lecznar1
lecznar1's Avatar
alright thax alot for the help guys i think i'll go get some loc tite for that bia.. and no i'm not using the stock shifter handle it's all hurst... i'll try the loctite
lecznar1 is offline
carid
07-08-2016 09:55 AM
firehorse02
11-16-2015 11:28 AM
Explosive
10-02-2015 07:45 AM
guitarman376
09-30-2015 05:54 PM
junior04
09-28-2015 10:53 AM
Quick Reply: hurst shifter
