Trouble taken off brake lines off proportion valve
Old 07-20-2007, 12:05 PM
hatchdemon89
hatchdemon89's Avatar
Default Trouble taken off brake lines off proportion valve
i can't spell im tryin to disconnect the brake lines off propotion valve in engine bay cuz i can't get the brake booster out without it any ideas i tried wd40
hatchdemon89 is offline
Old 07-20-2007, 12:29 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Trouble taken off brake lines off proportion valve
take a small mini torch like one for soldering and heat around the fittings I had to do that to mine it usually works but make sure you have a line wrench and not a open end wrench!!! all that'll succeed in doing is f'ing up the fittings
mjr46 is offline
Old 07-20-2007, 06:07 PM
blwn93gt
blwn93gt's Avatar
make sure you have a good line wrench too. i used to have a cheap set from craftsman and the end of it always wanted to spread out and round off the fittings. i good a good set from snap-on and havent had a prob yet. i know they are expensive but you get what you pay for. im not sure if matco or other brands are good, i dont have experience with them.
blwn93gt is offline
Old 07-20-2007, 06:22 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Try tightening it a lil and then loosen it.
PRO50SC is offline
Old 07-20-2007, 09:44 PM
ALMOST STOCK
ALMOST STOCK's Avatar
Have you tried using a flare nut wrench, they're made for removing the nut you're taking about?
ALMOST STOCK is offline
10-07-2015 07:02 PM
EASTIDEE123
09-14-2015 03:52 PM
TfcCDR
09-14-2015 12:08 PM
DoctorScary
09-09-2015 07:53 AM
09-08-2015 11:50 AM
Quick Reply: Trouble taken off brake lines off proportion valve
