Can regular heat shrink be used on an in-tank fuel pump? I want to solder the wires together rather than use a crimp connector, then use heat shrink to cover the solder joint but I was wondering if the standard heat shrink you buy for electronics can be immersed in gasoline without decomposing.
Well if you want to solder is, do it. You don't need to heat shrink it. Butt connectors have no heat shrink and they work fine. Solder it. Won't change anything.
