Spark plugs for nitrous application - MustangForums.com
Sponsored by:
Sponsored by:
Old 07-21-2007, 02:50 PM   #1
ColdCityMustang
Default Spark plugs for nitrous application
I have a 1995 GT mustang , NOS recomends that the plugs be 2* colder than factory, does anyone ha\ve a NGK spark plug part number?
ColdCityMustang is offline   Reply With Quote
Old 07-21-2007, 03:18 PM   #2
WhiteWindsor
Default RE: Spark plugs for nitrous application
Callor e-mail their tech line, they willlet you know. I run autolite 3923 on 11:1 351. Autolite told me to step down to a 3922 with nitrous and retard timing.
WhiteWindsor is offline   Reply With Quote
Old 07-21-2007, 03:49 PM   #3
Mustangkiler
NGK 2249
Mustangkiler is offline   Reply With Quote
Old 07-21-2007, 04:52 PM   #4
my77stang
my77stang's Avatar
why are you running an NGK plug in a ford anyways? 99.999% of mechanics will tell you regular copper core autolites work the best, even for cars that arent fords
my77stang is offline   Reply With Quote
Old 07-21-2007, 05:30 PM   #5
Mustangkiler
NGK is where its at
Old 07-21-2007, 09:10 PM   #6
samseed101
How big of a shot are you running? What plugs to get usually depends on that. Of course, I'm a fan of copper autolites myself.
samseed101 is offline   Reply With Quote
Old 07-21-2007, 10:14 PM   #7
ZachW04Stang
NGK is a brand not a type of plug. I was reading up the other day in a magazine that for nitrous you use an ngk brand plug because the electrode is smaller and if the combustion chamber temps get to hot from leaning out the electrode on the plug will melt because its smaller then autolite and other brands. It ends up saving your motor and just destroying the sparkplug. Just a thought
ZachW04Stang is offline   Reply With Quote
Old 07-21-2007, 10:16 PM   #8
ThrashN
I run motorcraft plugs with a 100 shot, timing set at about 10-12
ThrashN is offline   Reply With Quote
Old 07-21-2007, 10:30 PM   #9
1fastzook
Im pretty sure that you have to go to a higer plugnumberfor NGK'S unlike american plugs autolite..ect ,you go lower.
1fastzook is offline   Reply With Quote
Bad cylinder? Dathan V6 (1994-2004) Mustangs 4 10-05-2015 05:52 AM
04 Mach 460 system, Installed Aftermarket HU, No Highs/Tweeters breaking Audio/Visual Electronics 5 10-02-2015 01:27 PM
Clear codes on '94 sn95 BOB ROME 5.0L (1979-1995) Mustang 2 09-28-2015 11:10 AM
Slight surge at 1500ish rpm lmurf60 4.6L (1996-2004 Modular) Mustang 1 09-24-2015 10:07 PM
125, 2011, 351, 50, 96, flow, ford, good, gt, mustang, ngk, nitrous, plug, plugs, spark, trick
