rocker upgrade - MustangForums.com
Old 07-21-2007, 04:27 PM   #1
steel1
steel1's Avatar
Default rocker upgrade
I've been kicking around the idea of putting in a set of rockers in my 93 GT. The heads are stock, but I have a typhoon intake, u/d pullies,cai,65mm tb,70mm maf, full pypes exhaust w/x-pipe, 3:73s. Which would be a better option 1.6 or 1.7? The car is just a weekend cruiser that I'm building on a budget. Also what would a stock head require, stud or pendant mount and would I need different pushrods? Would the 1.7s beat the heck out of my springs or should the springs be replaced when making the upgrade? Finally can I use my stock valve covers with either rocker?
steel1 is offline   Reply With Quote
Old 07-21-2007, 05:07 PM   #2
Mustangkiler
Default RE: rocker upgrade
1.7s would be the only reason to do it, and they can fit under stock valve covers if you take out the baffles, pedestal mount rockers, if you go to blueovalindustries.com you can use those with stock length pushrods,i dont know about the springs though.
Mustangkiler is offline   Reply With Quote
Old 07-21-2007, 05:18 PM   #3
1991LX5.0
i had 1.7's on the stock headson my car for about 4 years and never had any problems. I had the stock valve covers and still had the baffle in it
1991LX5.0 is offline   Reply With Quote
Old 07-21-2007, 05:46 PM   #4
steel1
steel1's Avatar
Sounds like changing to 1.6 isn't worth the effort, what ratio are stock rockers?
Old 07-21-2007, 05:53 PM   #5
my77stang
my77stang's Avatar
stock is 1.6
you'll gain a couple hp due to less friction, but the majority of the gain is by stepping to a 1.7 to give ya some added lift
my77stang is offline   Reply With Quote
Old 07-21-2007, 09:50 PM   #6
stang8689
1.7 will act like you have a bigger cam
stang8689 is offline   Reply With Quote
Old 07-21-2007, 10:30 PM   #7
luckythirteen13
luckythirteen13's Avatar
complete waste of money. get a bigger cam first and some heads.
stock heads are pedastal mount and aftermarket heads are stud mount. they make ped mount heads but who wants non adjustable rockers without using shims.
luckythirteen13 is offline   Reply With Quote
Upgraded PaulH2 Members Rides and Car Show Section 20 01-31-2016 10:48 AM
Engine tick Sixer4Life V6 (1994-2004) Mustangs 5 10-12-2015 05:26 AM
UPR Products Rockin the Lethal Performance Grille Delete Combo! Boostaddict Lethal Performance 0 10-01-2015 09:58 AM
UPR Products Rockin the Lethal Performance Grille Delete Combo! Boostaddict 3.7L V6 S550 Tech 0 10-01-2015 09:57 AM
2001 V6 Sixer4Life New Member Area 4 09-28-2015 08:05 AM
50, mustang, rocker, rockers, upgrade, upgrading
