LSD
Old 07-21-2007, 08:03 PM
reno27
reno27's Avatar
Default RE: LSD
ok
reno27 is offline
Old 07-21-2007, 08:29 PM
331StrokerFox
I ♥ Acer
331StrokerFox's Avatar
Default RE: LSD
The eaton posi was nice...no promblems ever. When dealing with rear ends it is also the touch of the installer. And my shop is A+ on installing gears, axles, posi's,without any vibration/noise, etc
331StrokerFox is offline
Old 07-21-2007, 10:10 PM
ZachW04Stang
ZachW04Stang's Avatar
Default RE: LSD
You can rebuild for traction locks very cheaply. Its $50 for a rebuild kit, then you figure $15 at most for gear oil, $5 for friction modifier, and $10 for a new gasket. Then you pack the traction lock really tight (extra shim) and you have a like new limited slip unit for under $100.
Lets just put it this way my rebuilt 31 spline traction lock chirps the tires making corners.
ZachW04Stang is offline
Old 07-21-2007, 10:14 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: LSD
ORIGINAL: ZachW04Stang
Then it's too tight there buddy!
PRO50SC is offline
Old 07-21-2007, 10:16 PM
ZachW04Stang
Default RE: LSD
ORIGINAL: PRO50SC
Well I guess its a good thing I like em tight
Old 07-22-2007, 10:19 AM
reno27
reno27's Avatar
Default RE: LSD
where is your shop located at?
reno27 is offline
Old 07-22-2007, 12:47 PM
86 5.0L
86 5.0L's Avatar
Default RE: LSD
its a bad thing for your tires to chirp in a turn with the traction lok that means theres binding occuring[&:][&:]
86 5.0L is offline
Old 07-22-2007, 12:57 PM
r.barn
r.barn's Avatar
Default RE: LSD
+1, watch it Zach, good way to break something., they slip in turns for a reason.
r.barn is offline
nonstopred
07-31-2006 12:34 PM
V6MustangKnight
06-20-2006 10:03 PM
HxCory
06-02-2006 06:15 PM
TJ
05-16-2006 08:52 PM
Big Red
03-06-2006 10:25 PM
Quick Reply: LSD
