New question
#21
RE: New question
ORIGINAL: mattdel
if your sure the new module & coil are both good, and you are sure that you are losing spark, you need a PIP(profile ignition pickup).
its located inside the distributor, underneath the rotor.
requires distributor to come out and be disassembled to replace it.
#24
RE: New question
just be careful not to damage the gear on the end of it, and dont crack it anywhere. other than that, its pretty simple.
follow the correct procedures for re-installing it and your good to go.
#27
RE: New question
ORIGINAL: itsa87
Is there a sensor that shuts the motor off until cool down in a 87? And if my guage was screwed up and acted as if it was getting hot, would that shut it off? Plus when I drive the car then shut it off the temp guage climbs up to the top, most of the time it's when I turn my headlights on when the car is shut off.
2. '92 TBird/Cougar 5.0L WP was reverse rotation also.
3. To check what's causing the now start, you need to get the car into the condition and do some tests....check the EFI No Start link at this DIY KOEO/KOER/Cylinder Balance Self-Test page....just a thought.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
