clunking noise
Old 07-22-2007, 12:38 PM
PJB
PJB's Avatar
Default RE: clunking noise
If its the front check your swaybar mount/bushing and swaybar end link on that side
PJB is offline
Old 07-22-2007, 12:47 PM
wcfurious
wcfurious's Avatar
okay found the problem, need advice fixing it, photo coming in a few minutes
wcfurious is offline
Old 07-22-2007, 12:51 PM
wcfurious
wcfurious's Avatar
http://www.btlguild.com/btlgallery/a...1/DSC01139.JPG
Old 07-22-2007, 01:02 PM
wcfurious
wcfurious's Avatar
this is what the right front side looks like, seems like I'm missing something For someone not mechanically inclined, can you let me know what to ask for and how hard a fix this is? Looks like it just broke off
http://www.btlguild.com/btlgallery/a...1/DSC01143.JPG
Old 07-22-2007, 02:10 PM
vtecwho
vtecwho's Avatar
if you hit a bump hard it probably broke your strut. i did the same thing. afterwords every decent size bump i hit it would click or clunk. if you replace your strut that should fix the problem.
vtecwho is offline
Old 07-22-2007, 02:15 PM
vtecwho
vtecwho's Avatar
oops, did not read all the way down. if you follow that to the bottom you should beable to unbolt the whole thing and replace it.
vtecwho is offline
Old 07-22-2007, 02:19 PM
wcfurious
wcfurious's Avatar
better picture, what exactly is it called and how hard would it be for me to replace it?
http://www.btlguild.com/btlgallery/a...1/DSC01164.JPG
Old 07-22-2007, 02:22 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
broken sway bar link.....go to autozone and buy a new one cheap repair
mjr46 is offline
Old 07-22-2007, 02:34 PM
mjr46
mjr46's Avatar
easy job will take 5 min to unbolt....... 15 if it's rusted in place in that case cut it off!!
mjr46 is offline
Old 07-22-2007, 04:15 PM
wcfurious
wcfurious's Avatar
20.00 after tax Canadian about to go fix em, will post back after it's done, thanks all!
Quick Reply: clunking noise
