Trick flow valve covers
So, I installed my trick flow valve covers today. The only problem I have is there is no where for the oil fill to go. There is no hole in either valve cover. Did they send me two of the same valve cover, or do I have to drill the hole in the cover myself?
RE: Trick flow valve covers
yeah the second one u have to drill them yourself, not a big deal i drilled a hole in mine no problem, i think i used a 1 inch hole saw and filed the edges for the trickflow oil fill
I had the same problem....if you do a search you would find me all upset about it
Don't make the same mistake I did and try to make a circle with a Dremel because I was too lazy to go out and get a hole saw.......which I finally did anyway
Get a hole saw....and do it right.
ORIGINAL: CantStopTheFox...
ORIGINAL: jtmustang
so u are puttin the kit on cool let us no how she runs i am almost ready to rebuild mine and put the kit on two.
I bought some trickflow valve covers on ebay... finish my hci and have the passenger side cover on and NOTICE the stupid passenger side valve cover hit my throttle cable bracket... WTF... so i have a stock valve cover on the passenger side and a trickflow on the driverside... gay...
-Jeff
-Jeff
sounds to me like these trick flow covers are a waste of f*cking money. i mean seriously....... who doesnt give you a place to add oil?!??!?! if your running a car that for some reason DOESNT need it, you could always block the damn thing off. and what about a breather? or a pcv valve?
ford motorsport covers ftmfw!
