transmission problem? Car shakes around 45mph
Old 07-23-2007, 02:46 PM
95stangt
95stangt's Avatar
Default transmission problem? Car shakes around 45mph
I have a 1995 GT automatic and recently when the car shifts into OD at around 45mp and cruises around 40-55mph the car will tend to hop a bit, as if the car is trying to shift or something. I had a similar situation two summers ago and had the entire transmission redone but the shuddering was horrible back then and made some serious noise. This time around, the shuddering only happens every so often, normally when the car is warm. Is this a problem with the clutch sticking, a bad sensor, any ideas? Thanks
95stangt is offline
Old 07-23-2007, 02:52 PM
89 fox
89 fox's Avatar
Default RE: transmission problem? Car shakes around 45mph
not much to go off of there...but kinda sounds like the torque converter goin out...
89 fox is offline
Old 07-23-2007, 04:02 PM
grumpyphillips
grumpyphillips's Avatar
I had a similar problem with my 1995 V6. It ended up being a broken motor mount.
grumpyphillips is offline
Jskeezy84
09-08-2015 01:40 AM
FD725
08-23-2015 06:43 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: transmission problem? Car shakes around 45mph
