Fuel pressure regulator?
I think mine is bad on my stang. If you hook up the fuel pressure tester will it still show good fuel pressure? I'm getting 35-40 psi. It won't go over 3k rpms and the check engine light isn't on.
Also, why would my brake light be on? It stays on all the time and I know the brakes aren't sticking.
RE: Fuel pressure regulator?
your fuel pressure is slightly low....
as for your brake light issue...look under the dash...there is a brake light switch you need to change to make the lights go off...
Brake indicator could be a problem with the e-brake handle switch, brake fluid level switch at the main pump, or a problem with the proportioning valve. Do suggest the following:
1. DIY KOEO/KOER/Cylinder Balance Self-Test
2. Check if the problem with the 3k rpms "rev limiter" happens with the SPOUT connector removed from the TFI harness..
mrappe
09-26-2015 10:16 AM
