Putting Timing chain on.. Need a little help
Aright i got the thrust plat bolted up over top the cam shaft end, then i put the two timing chain gears n chain on lined up perfectly with number 1 TDC, But what keeps the camshaft from moving back and forth? dose the L shape plate n nut that go's over the top gear tighten up that slack? i got pics if you guys need them.. thanks guys
RE: Putting Timing chain on.. Need a little help
there should of been what they call a camshaft trust plate blocking the removal of the cam it's held on by two small bolts that get torqued to 11 ft lbs
well i got that tourqed.. but its movn like |---------| that far.... not sure if thats right ya ill have to do that then zach.. cuz i got the thrust plate n all on and then i put the gear on and u can move the cam gear like farther then u should be able to.. more then ud think anyway.
ORIGINAL: ZachW04Stang
Your susposed to have some camshaft endplay. You might want to search google and see what endplay specs are.
lets see some pics.
KEM Motorworks
08-14-2015 10:13 PM
