500hp rear end build q's?
07-23-2007, 10:07 PM
hey all i am in need of a 8.8"+ and i was wondering what car/truck rear end will fit into mine.
thanks all
UPDATE: i was wondeirng what i woulod need to do to a 8.8" to with stand say 500hp?
07-23-2007, 10:10 PM
RE: what rear end will bolt into a 86 stang?
they will all fit...
some will be wider
truck axles will need fab work for control arm mounts..
etc..
i was looking to convert to 5 lug, so would the ranger rear end fit in? or are the mounts differnet?
07-23-2007, 10:12 PM
fab work for lowers or upper mounts?
lowers are ok i wouldnt mind fabing up some stuff. but are there some that are like shorter in width??
07-23-2007, 10:18 PM
is the 8.8 you have now f*cked?
07-23-2007, 10:19 PM
truck axles use leaf springs, there are no control arm mounts. you will need to measure a mustang 8.8, cut and weld your mounts on.
make all the necessary adjustments for differences in total axle widths.
07-23-2007, 10:20 PM
i have a 7.5", this car is an original 2.3l. i am converting to a 351w. if it was a 8.8 i would rebuild it.
07-23-2007, 10:23 PM
ok then looks like i will be getting a 79-93 stang rear end. what should i build this thing with to withstan d say, 500hp?
07-23-2007, 10:24 PM
the 7.5 is the same width as a mustang 8.8, and you can use the control arm mounts you already have, if you do happen to purchase a truck axle.
as a matter of fact i have an explorer with an 8.8 sittin in my yard, collecting rust and hornets.
if your near me, $75, you rip it out, its yours.
