Throw out bearing went up
Throw out bearing just about went up on the way home last night, which is fine because it was almost time for a new clutch anyways. I'm going with the King Cobra clutch, since I'm not pushing too much HP and won't be for a while.
My question is, what tranny fluid does everyone use? I figured while i have it out might as well frain and refill.
RE: Throw out bearing went up
ORIGINAL: mjr46
I use royal purple syncromesh.... works great or some type of synthetic auto tranny fluid will be fine.
yes the syncromesh is for manual trans... it felt like it did before the change normal....the only reason I switched is I saw a dyno test run (horsepower tv) using standard fluids and after all fluids were switched to royal purple the camaro they used as a test car picked up 8 rwhp. whether or not it works I figured it's worth a try
KingRando
10-02-2015 08:06 AM
Offendant
09-23-2015 07:21 PM
