351 heads
Old 07-25-2007, 05:41 AM
90lxrider
90lxrider's Avatar
Default 351 heads
is anyone running 351 heads...??? does anyone know anything about D0OE heads..?
90lxrider is offline
Old 07-25-2007, 09:39 AM
my77stang
my77stang's Avatar
Default RE: 351 heads
i am, i run C90E 351w heads which are the same as the D0OE. they are similar in flow and performance to the GT-40 heads. same size intake runners, same size valves. 60cc chambers IIRC. what you need to do to make them streetable is get hard ex. seats installed if they arent installed from the previous owner, and take a dremel tool to the bumps in the exhaust ports, you can completely grind them away - there is plenty of meat there.
alot of people will tell you that gt40 heads still choke a 302, but i can attest to my 302 zinging up to 7k with a quickness and wanting to run alot higher than that if i would have let it.
my77stang is offline
Old 07-25-2007, 11:04 AM
aode08
aode08's Avatar
port the intake and exhaust 1/8th an inch, have a machine shop mill the heads .020, and install 1.7rollers, or a cam not exceeding a .530 lift, get some shorty headers or long tubes. Good for 45 hp.
aode08 is offline
Old 07-25-2007, 11:49 AM
my77stang
my77stang's Avatar
stock springs are good to .500 but really its more like .475 - anything past that and your pushing it to possibly break one, bind one, or float a valve.
Old 07-25-2007, 04:09 PM
89GTdude
89GTdude's Avatar
Im running the 70dooe heads mine are milled down to 57cc chambers, ported, enlarged bowls, and have chevy 1.94/1.6 valve's put in them. I have a x cam with .542 lift andit works good with the heads. Stock these heads are about the same as gt40's but if you put some money into them you can get good results and make just as much power as alot of aluminum heads.
89GTdude is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
mustangheaven
10-07-2015 10:23 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: 351 heads
