wont start
Old 07-25-2007, 09:13 AM
rembull
rembull's Avatar
Default wont start
1993 gt40 rebuild. Wont start have spark and fuel. At least the gauge at the schrader valve says 38psi. Does this mean though that each injector is pumping fuel. Unfortunately reversed the battery leads and smoked the selenoid. What would be the next step assuming something else is smoked?
rembull is offline
Old 07-25-2007, 09:50 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: wont start
Your missing something somewhere?? is it a weak spark??? are the injectors pulsing???you can check for injector pulse with a noid light or a test light.
mjr46 is offline
Old 07-25-2007, 10:00 AM
rembull
rembull's Avatar
I don't know a weak spark from a strong one visually. I replaced the coil and ignition module. I will have to buy a noid light to check injectors. If it is weak what else could cause it.
rembull is offline
Old 07-25-2007, 10:05 AM
mjr46
mjr46's Avatar
you'll need to verify that you have 12volts supplied to coil with a volt meter if you've got a voltage drop somewhere due to frying a component it can cause lots of problems but first things first check for injector pulse via noid light
mjr46 is offline
zsmart
Convertible Tech
02-29-2016 08:33 AM
1TUFF302
11-05-2015 04:02 PM
StalkerGT
09-25-2015 02:41 PM
dalefrancis88
09-11-2015 07:15 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: wont start
