shutting that tube going to the exhaust???
Old 07-25-2007, 10:57 AM
telsonman
telsonman's Avatar
Default shutting that tube going to the exhaust???
ok, so when i put my o/r h pipe on, i had to take a hacksaw to that little pipe that comes down behind the old cats. its that tube that makes the cats work right. anyway, what should i do about it. its just hanging there open, same with the one on the h pipe. should i get both of them welded shut, or can i take that pipe off up by the engine or wherever it goes to. a little help here...
telsonman is offline
Old 07-25-2007, 11:10 AM
ZachW04Stang
ZachW04Stang's Avatar
Default RE: shutting that tube going to the exhaust???
I welded mine shut. You could get a silicone heater hose, probably 5/8's and just stick it on with a hose clamp, then stick a bolt in the other end with a hose clamp.
ZachW04Stang is offline
Old 07-25-2007, 12:13 PM
nseoi
nseoi's Avatar
eliminate your smog system
nseoi is offline
Luke9222
10-22-2015 11:55 PM
09-24-2015 09:18 PM
BrantleyS550
09-14-2015 04:18 PM
09-10-2015 08:39 PM
Quick Reply: shutting that tube going to the exhaust???
