GT-40 cast iron heads on 347 HELP!! - MustangForums.com
Old 07-25-2007, 03:06 PM   #1
86gt_wit_Ts
Default GT-40 cast iron heads on 347 HELP!!
I have a set of cast gt 40 heads ported & polished with stockvalves and springs. I dont know what they flow. I was thinking about putting them on a 331 or 347 shortbk with BBK SSI intake Anderson Ford
B-31 cam. forced induction later. What do you guys think.
86gt_wit_Ts is offline   Reply With Quote
Old 07-25-2007, 03:10 PM   #2
FivePointOhh
in limbo
FivePointOhh's Avatar
Default RE: GT-40 cast iron heads on 347 HELP!!
Quote:
ORIGINAL: 86gt_wit_Ts
with that thing ^^^ = poop
are you a budget build? if your gonna be skimpy on you build get a gt-40 intake or something that looks good like the typhoon intake
**edit** your stroker kit will not be able to operate at its potential if you use very limited products, gotta have the flow to go!
FivePointOhh is offline   Reply With Quote
Old 07-25-2007, 03:14 PM   #3
86gt_wit_Ts
What about the heads? What out performs the SSi?
Old 07-25-2007, 03:25 PM   #4
w8less
w8less's Avatar
don't skimp out on the heads!!!!! trust me!!! i had completely reworded e7's with bigger valves. it suffocates the motor.
at least some trickflows, afr, canfields, eddy's something.
get a holley systamax or trickflow r and a custom cam. with boost friendly compression it will still make some power
w8less is offline   Reply With Quote
Old 07-25-2007, 03:33 PM   #5
86gt_wit_Ts
I want to make 400 to the wheels give or take on motor alone 9.5comp. give me an example part list to go on .
Old 07-25-2007, 03:37 PM   #6
FivePointOhh
in limbo
hehehe.....everything. if your on the cheap i suggest, typhoon from pro. products, lots of room to be worked, very thick casting. if your looking for performace then i suggest holley systamax or trick flow R as listed above.
custom grind i agree on.
heads, dont go cheap
Old 07-25-2007, 03:46 PM   #7
86gt_wit_Ts
bump
Old 07-25-2007, 04:12 PM   #8
FivePointOhh
in limbo
price range? if your looking for ideal set up, get something like RHS 180cc alum heads or AFR 165cc, Eddy RPM performer II, Typhoon, or Holley Systamax intakeand a custom grind cam. with your stroker kit you'd be close but put a 100 shot of juice for good measure and you'd be at 400 fo sho!
everyone will have an opinion, most of them all will work to get you at 400HP
Old 07-25-2007, 08:26 PM   #9
tinman
I recently saw the spec's on the Anderson cams.
I wasn't impressed in the least.
You'll do better at Comps for about the same $$$$$$$...........
tinman is offline   Reply With Quote
Old 07-25-2007, 09:04 PM   #10
nitrous_bob
nitrous_bob's Avatar
is this a daily driver ? thrashing at the track every weekend ? or a combo of both ?
asking for 400 hp, i assume you want to go mid to hi 11's since thats what 400 true hp will get you
you don't need a stroker for 400 hp, not at all. here was my buddies setup and he went 11.60 or 11.80 (he swapped out to a c4 from his t5 and i don't remember what time went with what tranny)
anyways....bone stock 302shortblock, '92 gt almost full weight(removed sway bars and rear bumber inner)
gt40 heads, ported exhaust, slight ported intakes, a little deck to get them to 10:1 compression, some kind of upgraded valve springs, but nothing major
stock cam , stock crank
box stock gt40 intake (real one...nothing looks better)
4.10 gears
125 dry NOS 5115
et drags 26X10.5
65 tb
80mm maf pro-flo
24 lber's
255 fp
launched at 5k on the spray, yankedan ez foot, et'd at 11.80 and 11.60 on each trans
totalinvestment ? probbaly $2900 tops
those hard launches did break 2 axles so he went 31 spline mosers, then he broke the t5 thats when he went c4 and never broke anything again
if you want 400 on all motor, then stroke it, those heads will work though, i like them alot
stroker + blower or 100 shot = 500 hp and 10's all day long, i have 2 buddies like that, a 327 crate motor and a 347 kit from anderson i think
nitrous_bob is offline   Reply With Quote
351c heads mustangheaven Motor Swap Section 3 01-03-2016 12:20 PM
extnesion for radio antenna to head unit kevsgt 2005-2014 Mustangs 5 10-09-2015 11:12 PM
Head swap mustangheaven Classic Mustang General Discussion 2 10-07-2015 11:23 AM
4 Valve Head questions GimpyHSHS 4.6L (1996-2004 Modular) Mustang 6 10-01-2015 10:01 AM
cost to rebuild heads Drastang 4.6L (1996-2004 Modular) Mustang 2 09-30-2015 04:48 AM
347, 40, canfield, cast, castiron, cracked, e7, ford, gt, gt40, head, heads, horsepower, iron, ported
