Clutch quadrant, firewall adjuster ?'s
RE: Clutch quadrant, firewall adjuster ?'s
ORIGINAL: mattdel
damn pro, you keepin tabs on everyone huh...
got your notepad right there with ya and everything dontcha
ORIGINAL: blkonblk5.0
I also have the steeda quadrant, and firewall adjuster..works real good I like it.
ORIGINAL: PRO50SC
You mean like this one? https://mustangforums.com/m_2974495/tm.htm[&:]
ORIGINAL: 86 5.0L
Search
The Steeda quadrant and firewall adjuster are good
Search
OK, you guys are telling me what pieces you have, my main question is are the for use w/ a stock cable??
why wouldn't it work with a stock cable? Isnt the ford cable the same as the steeda cable just more expensive?
the tripple is supposed to alow you to adjust pedle hight some how the single im not sure if its just for when you dont have the fire wall adjuster or for when you do. the double is for if you have the adjuster or do have it
ORIGINAL: PRO50SC
The stock cable is not adjustable. I think some of those kits use longer, adjustable cables. NOt what I want.
I have the steeda cable, which is smoother sliding than a stocker, and i use a single hook steeda quadrant, and the firewall adjuster. oh, UPR sells the quick click adjuster, and that way you dont have to loosen the allen head screw when you need to adjust it.I dont know about anyone who has this one, but it seems sweet! Hope this helpsBern.
ORIGINAL: XSRACINGGT
