347ci wanting to go turbo
Old 07-27-2007, 09:02 AM
luckythirteen13
luckythirteen13's Avatar
Default RE: 347ci wanting to go turbo
ORIGINAL: greenstreak9205
ORIGINAL: luckythirteen13
thats with stock displacement. with a 347 you need good flowing heads even if you do run a turbo.
bah! why use good parts? it takes all the fun outta it [8D]
he is already using good parts, he stroked it to 347. forced induction or not, a bigger motor still needs bigger heads to breathe correctly
luckythirteen13 is offline
Old 07-27-2007, 02:35 PM
greenstreak9205
greenstreak9205's Avatar
i'll give you the benifit of the doubt since its over the internet, but there was a bit of sarcasm there
greenstreak9205 is offline
Old 07-28-2007, 08:12 AM
mccarterjg
mccarterjg's Avatar
ok. well would 14.5psi be thinking too high
mccarterjg is offline
Old 07-28-2007, 09:13 AM
TwotoneVert
TwotoneVert's Avatar
You need to hook up with ruger311, he will be running a 347 turbo, but he has a dart block and was built to take the punishment, he knows his stuff.
TwotoneVert is offline
Old 07-28-2007, 11:00 AM
aode08
aode08's Avatar
64cc heads, not milled.
gap the rings for boost.
Good head gasket, and conservative boost.500rwhp and lightweight roatating assembly will save the stock block.
aode08 is offline
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
richard1027
09-09-2015 07:23 PM
baron95
09-06-2015 09:24 PM
whatsup62
09-03-2015 01:38 PM
09-01-2015 08:16 PM
Quick Reply: 347ci wanting to go turbo
