Torque Converter ?
Torque Converter ?
If I installed my torque convertor without any fluid in it when i put my trans back in will it fill itself up? The whole transmission was empty when i put it in and its slowly taking more and more fluid the longer it runs so i'm guessin thats what is happening. I would think it should but i'm just curious. Its the stock convert and trans out of my 83 so its nothing special to get ruined (c5).
RE: Torque Converter ?
i really dont know. prolly because me and my brother had to lift the tranny in place without a jack and neither one of us are big by no means. but still no one has answered my question.
yes the converter will fill it self up but the way you are supposed to do it is put about half a quart in the converter when you put it on the tranny. then when the tranny is bolted int, put about 4 quarts in the tranny. jack the rear wheels up and start the car in neutral. with motor running, fill the tranny one quart at a time with the tranny in 1st. an aod will hold 10 quarts give or take depending on pan size and converter size
I have never fill the converter I just put it in the trans. and put it in the car put 8 qt trans. fluid in and start it up and run it threw the gears on the jack stands and get it good and hot. I also tell the customers I do C-4s for to do the same no problems yet.then I add till its full.
