Gear problem?
Gear problem?
I just installed 3.55 gears in my car today. The problem is that they will turn backwards with ease, but when turn them forward you almost have to use a bar. What do you think is wrong?
RE: Gear problem?
Need more info. I am assuming this is on a 93 Stang with an 8.8.
As a general rule of thumb, you can usually get away with installing the same pinion bearing shim or at least one of the same thickness on FMS gears and the same crush collar.
If your gears are not Ford Motorsport gears, then all bets are off and you will need to setup the rear end from the ground up.
What do you have?
Rick
What do you have?
Rick
musnicki
09-23-2015 07:11 AM
