having trouble firing motor
07-26-2007, 11:18 PM
RE: having trouble firing motor
its not all at the same time ill bend two and then ill bend four more its ramdom i cant figure it out
07-26-2007, 11:19 PM
when does it happen? launching from a light, or long sustained high revving, like WOT in 4th, or what?
07-26-2007, 11:24 PM
no i cant get it started it does it cranking
07-26-2007, 11:26 PM
how did you torque the rocker arms?
07-26-2007, 11:31 PM
just tightened them untill the then push rod had no play in it and then locked them in place
07-26-2007, 11:34 PM
u spun the motor over to TDC at each cylinder while u tightened the rockers right?
07-26-2007, 11:36 PM
ya of course
07-26-2007, 11:43 PM
ummm... well i dunno then
if you are sure your not hitting the piston, and the valvetrain is properly put together
where are they bending? up close to the rocker, or down further towards the lifter?
07-26-2007, 11:45 PM
they are all breaking at the rocker
07-26-2007, 11:48 PM
are you using stock valve springs?
