having trouble firing motor
07-27-2007, 12:40 AM
RE: having trouble firing motor
there ya go.
thats alot of duration.
07-27-2007, 12:42 AM
im pretty sure thats the duration im not a hundred percent positive
07-27-2007, 12:48 AM
thats right 288 duration the part number on the cam is M6250F303 can any body look it up and tell me if im correct on the duration
07-27-2007, 12:50 AM
yes u are
what pistons did you buy
keep in mind that the valves in those heads are larger than stock, a stock replacement piston will still need notching/flycutting
07-27-2007, 12:56 AM
i have the speed pro L2483F pistions my local speed shop said they would clear my valves
07-29-2007, 12:21 AM
fixed the push rod problem i got hardened pushrods the valve springs are set up for .600 lift and thats to much for the stock push rods
CS2007
06-25-2019 09:45 PM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
ChampInSD
10-02-2015 04:55 AM
