bad temp gauge or something else?
Old 07-28-2007, 12:01 AM
ctgreddy
ctgreddy's Avatar
Default bad temp gauge or something else?
well lately my temp guage has made me scratch my head. sometimes when its really hot it only goes about a quarter of the way up. and it stays there. then other times even when im not getting on it it goes all the way to three quarters of the way up then stays there for a while...then it'll eventually go back to the middle. and another thing...if i watch it...i can see it swaying back and forth. it dosent like to stay in one place for very long. so please tell me a sensor is bad or something.
ctgreddy is offline
Old 07-28-2007, 12:04 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: bad temp gauge or something else?
the stock analog factory gauges are useless they say c and h ...c for cold and h for hosed!!!!!/screwed the first thing you need to do is verify gauge operation by installing a mechanical gauge= much more accurate and if the same thing happens then you have a cooling system problem.
mjr46 is offline
Old 07-28-2007, 12:06 AM
ctgreddy
ctgreddy's Avatar
by mechanical guage you jsut mean like an aftermarket autometer one right?
and would it be hard to hook one of those up?
ctgreddy is offline
Old 07-28-2007, 12:10 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Check to see if the coolant is full. If it is, you may need a new t-stat or have a problem w/ the radiator fan
PRO50SC is offline
Old 07-28-2007, 12:11 AM
mjr46
mjr46's Avatar
mechanical gauges are easy to hook up cause all they have is a sensing probe like an autometer one.
mjr46 is offline
Old 07-28-2007, 12:23 AM
ctgreddy
ctgreddy's Avatar
well i know the coolant is full becuase i checked that.
but i heard about someone having a bad sensor that tells the fan when to turn on.
could this be why the temp goes to a certain point then drops down?
ctgreddy is offline
Old 07-28-2007, 12:27 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Yes
PRO50SC is offline
Old 07-28-2007, 01:02 AM
ctgreddy
ctgreddy's Avatar
where is the sensor for the fan at?
and can i get it from autozone or is it ford direct?
ctgreddy is offline
Old 07-30-2007, 11:31 AM
northy_polk
northy_polk's Avatar
ever figure this out? i just bought a 94 gt for the track and have the same problem. been told to get an autometer gauge from summit racing to see if it really is running hot. also, if you look back at the tsb's, there was one for "erratic temp gauge" on this year/engine, fwiw.
northy_polk is offline
Old 07-30-2007, 12:08 PM
ctgreddy
ctgreddy's Avatar
no i havnt figured it out yet. i just spent all my money on an exhaust that i needed. so it'll be next week before i can get a new gauge and see if thats the cause. ill keep you updated tho if you want me to.
ctgreddy is offline
Quick Reply: bad temp gauge or something else?
