getting mad.....
Old 07-28-2007, 04:22 PM
carsurplus
carsurplus's Avatar
Default getting mad.....
so my temp in the car is getting high like on O and R in normal... i jsut did a flush with the prestone flusher and filled up wit extra strength and distilled water took it for a drive and its still getting hot is that my radiator or what???
carsurplus is offline
Old 07-28-2007, 04:32 PM
TwotoneVert
TwotoneVert's Avatar
Default RE: getting mad.....
What temp is the t-stat? Have you check the fan clutch? If it turn easily after you have driven it, time to replace. Mine runs at a constant 180. That may bebit high, are you sure your gauge is accurate?
TwotoneVert is offline
Old 07-28-2007, 04:33 PM
carsurplus
carsurplus's Avatar
ok i replaced the clutch my t stat is 160
stould i get sumtin lower like 140
Old 07-28-2007, 04:41 PM
TwotoneVert
I wouldnt get any colder. I dont know the science behind it, but your car will run better with a higher temp t-stat. Someone else may be able to explain open and closed loops and how that works, I dont remember. I would make sure the radiator is clean, even though you just flushed it. Get a flash light and look in there, if you see build up, it will not cool as it should. Since you just replaced the fan clutch, there isnt much left except the t-stat, or water pump......how is that? No leaks or noises. Can you see the water circulating when the engine is running? Also make sure you get all the air out of the system, you have to burp the upper rad hose and keep adding water. Does it boil over and fill the bottle or just run warmer than usual?
Old 07-28-2007, 04:43 PM
carsurplus
carsurplus's Avatar
it jsut runs on O and R ima try burping it
Old 07-28-2007, 04:48 PM
86 5.0L
86 5.0L's Avatar
1st off replace the stat with a 180* or 190*
2nd the gauge is suppose to be right in the middle
86 5.0L is offline
Old 07-28-2007, 05:07 PM
tmajikman
tmajikman's Avatar
ORIGINAL: 86 5.0L
+1 the 160 will actually not allow the car to get hot enough and the computer will not be able to get out of its closed loop warm up condition until it reaches aroung 175 degrees.
tmajikman is offline
Old 07-28-2007, 05:11 PM
AndySpeed
AndySpeed's Avatar
might have air pockets in it if you just drained the radiator.. these can be a pain to get out.. Sometimes need a pressureized machine that shops use for this.. Ive seen many of problems with flushing radiators like this at work.
AndySpeed is offline
Old 07-28-2007, 05:18 PM
tmajikman
tmajikman's Avatar
I would just take the cap off and run the motor for 30 to 45 minutes and make sure the tstat is open and that should get the air out the system if there is any.
Old 07-28-2007, 05:20 PM
AndySpeed
AndySpeed's Avatar
ya that usaully dose it.. but its hard to have the car sitting still and try to get it up to tempature..
Quick Reply: getting mad.....
