AOD gears?
RE: AOD gears?
It depends on your rear axle ratio. If you have 3.55s or 3.73's (or 4.10's, then DEFINITELY), then i'd get a lower than average ratio. That will give you an extra 2-4 MPH an 1st and 2nd gear, which will help with your ring and pinion. If you have a high gear ratio in your rear axle (2.73, 3.13, whatever) then go stock or higher.
RE: AOD gears?
ORIGINAL: red9535
thats not what he asked at all
stock, the aod is 2.40 in first and 1.47 in second if memory serves. i think the only other choice you have is the wide gear set which is about 2.80 in first and 1.60 in second
RE: AOD gears?
ORIGINAL: luckythirteen13
ORIGINAL: red9535
See?
RE: AOD gears?
yeah the widegear set is 2.84 1st, 1.55 2nd and only other options i know of, it's the mark VIII stuff
i'd go w/ it......the whole kit gives better clutches and better od band too, so check it out b4 you end up w/ a bunch of extra parts.
assuming it's a DD or more street than strip, i'd do wide gearset, 3000 stall (precisions stallion) , and 4.10's
not so much street than 4000+
RE: AOD gears?
ORIGINAL: fishermanjesse
so will the widegear set make my car perform anybetter on the 1/8th ive got 3.73's if its not more than .2 of a sec then forget it.
